Clarification on GatewayContext Data Storage
In later versions of the SDK documentation I'm not able to find methods for accessing the data directories of Ignition.
Specifically this guide: Storing Configuration Data | Ignition SDK Programmer's Guide mentions GatewayContext.getHome() but this only seems applicable to older versions.
Is there a change to the mechanisms for dealing with file storage in Ignition?
Specifically - I'm simply wanting to allow document upload for a module however other forum posts mention using BLOBs in database instead, is file-based storage no longer supported?
See: GatewayContext (ignition 7.8.4-rc1 API)
And: GatewayContext (8.3)
Right after posting I came across this topic which seems to locate the required method: Is there a way withthe SDK to obtain the gateway data directory path? - #4 by PGriffith
I'm suspecting the SDK guide is out of date?
You can get a SystemManager from the GatewayContext, that can tell you a bunch of different paths.
