Well i am trying to setup a classic VA plot with the chart control. I have dataset using historical tag with the below settings. I then assigned this dataset to the chart and setup the two axis to numeric. but i am getting now values in the chart. Am i missing something?
Can you post a screenshot of the actual dataset? My guess is the quality of the data is bad or there is no data.
Dataset is fine. When running the chart as a time base chart it works fine. Also if you copy the data out of dataset into a new dataset and delete the t_stamp column i get the results i would expect. But if you delete the t_stamp column from the dataset linked to the tag history it flases with the correct data but then the t_stamp column gets added back into the dataset.
Travis i was just going to see if you had any ideas on what is going on here or if i need to go about this in a different manner.
Correct, the tag history binding always adds the t_stamp as the first column. I see what you are trying to do. In this case you have to make a new dataset in scripting since you can’t remove the t_stamp column. Do the following:
- Add a custom property to the root container called origData that is a dataset. Right click and select Customizers > Custom Properties.
- Bind it to the tag history binding you have right now
- Right click on the root container and select Event Handlers…
- Choose the propertyChange event and use code like this:
if event.propertyName == "origData": origData = system.dataset.toPyDataSet(event.newValue) newData = [] for row in origData: newData.append([row[1], row[2]]) event.source.getComponent("Chart").Data = system.dataset.toDataSet(["Col 1 Name", "Col 2 Name"], newData)Let us know if you have any questions.
