I have attempted connecting Ignition to Apache Phoenix via JDBC. As a test case I have also connected to the database using Squirrel from the same host where the Ignition gateway is installed.
After configuring both the Driver and Connection properties the connection status reads “Unknown”
When I view the console output I see the output below.
Additional information
security is not enabled on this database and I have provided no user name or password in the connection properties. I have tried it with a username and password as well with no effect.
The JDBC driver JAR that I am using should contain all of the necessary dependencies and this is verified by the Squirrel Client driver configuration
I have updated separate JARs containing these classes using the Driver configuration with no effect. I added JARs to the C:\Program Files\Inductive Automation\Ignition\lib folders with no effect
11:11:35 AM BasicExecutionEngine Task connection validation hbaseviaphoenix threw uncaught exception.
java.lang.NoClassDefFoundError: Could not initialize class org.apache.hadoop.security.UserGroupInformation
at org.apache.hadoop.hbase.security.User$SecureHadoopUser.(User.java:286)
at org.apache.hadoop.hbase.security.User$SecureHadoopUser.(User.java:282)
at org.apache.hadoop.hbase.security.User.getCurrent(User.java:185)
at org.apache.hadoop.hbase.security.UserProvider.getCurrent(UserProvider.java:88)
at org.apache.hadoop.hbase.client.ConnectionManager.createConnectionInternal(ConnectionManager.java:336)
at org.apache.hadoop.hbase.client.HConnectionManager.createConnection(HConnectionManager.java:144)
at org.apache.phoenix.query.HConnectionFactory$HConnectionFactoryImpl.createConnection(HConnectionFactory.java:47)
at org.apache.phoenix.query.ConnectionQueryServicesImpl.openConnection(ConnectionQueryServicesImpl.java:389)
at org.apache.phoenix.query.ConnectionQueryServicesImpl.access$300(ConnectionQueryServicesImpl.java:217)
at org.apache.phoenix.query.ConnectionQueryServicesImpl$13.call(ConnectionQueryServicesImpl.java:2348)
at org.apache.phoenix.query.ConnectionQueryServicesImpl$13.call(ConnectionQueryServicesImpl.java:2327)
at org.apache.phoenix.util.PhoenixContextExecutor.call(PhoenixContextExecutor.java:78)
at org.apache.phoenix.query.ConnectionQueryServicesImpl.init(ConnectionQueryServicesImpl.java:2327)
at org.apache.phoenix.jdbc.PhoenixDriver.getConnectionQueryServices(PhoenixDriver.java:233)
at org.apache.phoenix.jdbc.PhoenixEmbeddedDriver.createConnection(PhoenixEmbeddedDriver.java:142)
at org.apache.phoenix.jdbc.PhoenixDriver.connect(PhoenixDriver.java:202)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:199)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:155)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer$1.run(DatasourceManagerImpl.java:996)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:584)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
