Clean up designer memory?
Hello,
When I reaching my desinger memory limit...is there a way to clean it up?
Or just reopening the project would do?
Cheers!
Either the project is extraordinarily complicated, or you are doing something bad within it that is leaking memory. If re-opening the project resets the usage to near zero, it is probably project complexity.
If re-opening the project doesn't fix it, you are leaking memory and may need to get IA support involved. In the meantime, try a complete designer exit and restart.
This is a known issue if you have been opening multiple projects without restarting the designer.
Restarting designer will reset it.
cheers
The project has a lot of named queries binding, script transform and xy charts with these bindings. The memory goes so high when I do a lot of script transform on the tables and charts. Reopening the project bring it back to low numbers. I can live with it. In other pages I don´t need so much data manipulation.
Cheers
