How can I reset the S+F stats? In particular the "Total Dropped" count? It shows up in red with a warning icon despite not having dropped any items for a long time, and I don't see how I can reset it to get rid of the red. (It's also a very large number and it's disconcerting seeing it when it's no longer an issue.)
Just had this happen yesterday where it was dropping records becuase the VM ran out of disk space. Wanted to alarm on that number being anything other than 0, but would not work unless there's a way to reset it. Following for the answer. I'm sure I can utilize other tags to get the same result, but this would be nice and clean.
You should see this reset if you change a value in the S+F configuration and save.
