[code]headers = [“Value”,“Label”]
data = []
clear_data = system.dataset.toDataSet(headers,data)
event.source.parent.getComponent(‘Dropdown’).data = clear_data
[/code]
I have this code that clears the data on the my second drop down list ,
what about when I want to delete the records on the table when the label “” is chosen on the drop down list, kind of just clears the record…
I think this is what you want to do.
Add this code to the property change on the drop down menu:
if event.source.selectedLabel == '<Select>':
headers = ["Value","Label"]
data = []
event.source.parent.getComponent('Table').data = clear_data
Chris
it did clear the whole table. but i just wanted to clear the results that was on column 3
Like this:
#Set column number. Starts at 0 from left.
col = 2
temp_data = event.source.parent.getComponent('Table').data
for row in range(temp_data.rowCount):
temp_data = system.dataset.setValue(temp_data, row, col, '')
event.source.parent.getComponent('Table').data = temp_data
Chris
Cool it worked! Thank You!
