Ignition 7.8.1
I am implementing an Ignition system for a plant where there are certain alarms that should only trigger while the plant is running, so I am disabling the alarm when the plant is in standby.
However, if an alarm is triggered while the plant is running, but doesn’t clear before the plant stops, it just stays there, even after being acknowledged. Is there some way to clear alarms while they are disabled? Could I make it do that when the alarm is acknowledged?
I think the easiest way to do it would be through a script function that clears the alarm, but I don’t see any function for doing that. Any other ideas?
