my Click PLC is saving a value on C1 (Contact Normally Open Bit memory address).
From Ignition Designer I can’t retrieve the value on the OPC tag. I tried the following combinations with no luck:
Boolean | [Click_PLC]HR1 | [Click_PLC]DI1 | [Click_PLC]C1 | [Click_PLC]IR1 |
Byte | [Click_PLC]HR1 | [Click_PLC]DI1 | [Click_PLC]C1 | [Click_PLC]IR1 |
Ignition OPC UA Server is connected
Click_PLC device is connected via Modbus TCP
I was trying to troubleshoot data type Boolean but for some reason I didn’t get it to work.
[Click_PLC]C16385 worked with data type Byte.
Thank you guys
