I create a client string arrey tag, for example: Test, with index 5. I want to display Test[0], Test[1], Test[2] respectively on the screen, but when I bind it to the Text Lable, it display Error_TypeConversion, When I drag Test tag without array index , it will display a string array, while that is not I wanted.
My Ignition Version is 8.0.3.
Can anyone reply me?
I am facing the same issue with all client array tags
Previously running 8.1.13.
It appears that its fixed sometime recently after that, as it is working as intended in 8.1.19
