Client Crashing When Closing and Opening
Hello,
In my work, I have created a signage system for TVs around the plant. They each run as Vision clients that display PDFs uploaded by users. This was all contained in a single window.
In a new version update, I added the ability to display other Vision windows in rotation with PDFs. In order to make this work, I open a 2nd window and “hold” a timer on the original window. A timer on the 2nd window will close itself, and the 1st window will resume to the next item to display. The 1st window will NEVER close.
I got this implemented successfully. However, after coming in each morning, I noticed TVs that were displaying and closing 2nd windows would have their clients frozen. This makes me suspect that closing a 2nd window over and over is not entirely releasing memory.
Could this process be causing a memory leak? Just wondering if anyone has tried something similar and run into the issue. I can provide more information if needed. Thanks!
What do you see in the logs? I have projects where they are opening and closing windows many times an hour 24/7/365 and there are zero events like what you describe. Also if there is a bug causing this your version would help identify.
Just wanted to give an update. While I'm not sure what the exact cause of the memory leak was, it was obvious something between the constant calling of open and close desktop was causing a gradual increase in memory usage over time.
Regardless, I wanted to test this issue post upgrading our development server to 8.1.21. Keeping the same functionality that was causing eventual client crashes, memory usage stayed stable. It appears at some point this was addressed in an update between 8.1.7 (previous version) and now.
Will mark as solution when testing in full production environment.
