Is there a command or keyboard shortcut to open the client diagnostics console from a button/script? The only way i’m aware of getting to it is by enabling the client menubar and then navigating to Help>Diagnostics.
This would be really handy, since for all my clients, I hide the menubar. If we could pop up the diagnostics utility from a button, or even embed a console into a page, that would be fantastic.
This is answered in Launch Diagnostics/Console From Client. Use this script:
from com.inductiveautomation.factorypmi.application import FPMIApp
FPMIApp.getInstance().showFPMIDiagnostics()
Sorry for necrobumping, but I want to make sure I can quickly find the answer the next time I search for this and for whatever reason I found this thread with my initial searches but not the other thread.
Or, y’know, system.gui.openDiagnostics - Ignition User Manual 8.1 - Ignition Documentation… man, what was that guy in 2018 thinking
Is there a way (either with Robot or through script) to select console once diagnostics is open?
from java.awt import Window
# Returns the first nested component of a given class
# container = The object containing nested components to be recursively searched
# className = the __name__ of the class given as a string
def findComponentOfClass(container, className):
for component in container.components:
if component.__class__.__name__ == className:
return component
else:
foundComponent = findComponentOfClass(component, className)
if foundComponent:
return foundComponent
# Programatically open a diagnostic window, find it, and set it to the console tab
system.gui.openDiagnostics()
for window in Window.getWindows():
if window.__class__.__name__ == 'DefaultPopupWindowParent':
diagnosticDialog = findComponentOfClass(window, 'DiagnosticsDialog')
if diagnosticDialog:
tabbedPane = findComponentOfClass(diagnosticDialog, 'JTabbedPane')
tabbedPane.selectedIndex = tabbedPane.indexOfTab('Console')
neat, thank you so much @justinedwards.jle
