in trying to run the script below on a tag change event:
trigger = system.tag.readBlocking(["[CC_OEE]TrumpfTags/2267/TruLaser (L52)_A1230E0148/Machine/Flag"])[0].value
date = system.tag.readBlocking(["[CC_OEE]TrumpfTags/2267/TruLaser (L52)_A1230E0148/Machine/endtime"])[0].value
if trigger == bool(1) :
id = system.db.runNamedQuery(“Enterprise/site specifique/pull”,{“date”:date})
start=system.db.runNamedQuery(“Enterprise/site specifique/debut”,{“id”:id})
end= system.db.runNamedQuery(“Enterprise/site specifique/fin”,{“id”:id})
system.nav.openWindowInstance(“SiteSpecific/fault description”,{arret:id,debut:start,fin:end})
system.nav.centerWindow(“SiteSpecific/fault description”)
no window opens in the vison client session . any help or suggestion is welcomed
When asking questions like this where you are shoing code, you can format the block by highlighting it and, and pressing the ‘Preformatted Text’ button (looks like </>)
id = system.db.runNamdQuery("Enterprise/site specifique/pull",{"date":date})
start=system.db.runNamdQuery("Enterprise/site specifique/debut",{"id":id})
end= system.db.runNamdQuery("Enterprise/site specifique/fin",{"id":id})
system.nav.openWindowInstance("SiteSpecific/fault description",{arret:id,debut:start,fin:end})
system.nav.centerWindow("SiteSpecific/fault description")
You can open the diagnostics either through the help menu or Ctrl+Shift+F7
That said, you need quotes around arret, debut and fin parameter names on the openWindowInstance() line
thank you, i’ll try and hope it’ll work
