Client Event Timer Enabled/Disabled
Hi there,
I wonder if anyone can help? I have created a client event timer script which I want to count to 5 seconds and then reset a tag value. This bit all works absolutely fine but as the client event script is always running I don’t know what the value of my timer is at a given time. Therefore I want to enable it and disable it from a button script but I can’t seem to find the path to the timer.
Does anyone know how I can enable and disable my client event script at runtime?
Thanks in advance
Kevin Lee
You could have your client event script check a memory tag boolean value which you could use to enable/disable that section of script?
so in your script you’d have something like:
enabled = system.tag.readBlocking(["PathTo/TagToEnableScript"])[0].value
if enabled ==True:
      #Do things
Hi Jonathan,
Thanks for your reply. I think what you have written is exactly what I am looking for but I do not know the path to the client event timers?
Kind Regards
You will find them in here
