I found an issue using ‘openWindowInstance’ to open multiple times the same window.
To replicate the bug, I created a small project, containing only a main window and a popup window.
On the main window I just created a push button that opens the popup using the function openWindowInstance.
If I run the project, open two popups and then publish the project using ‘File/Save and publish’, even without making any change to the project, the client updates correctly for the first few times, then it freezes and uses a lot of cpu (usually the forth time the project is published, just keep both popups open).
If I do the same procedure with just 1 popup, the client updates correctly every time.
I attached the project I used for this test.
The gateway runs on a server with Windows Server 2008 R2 SP1, while I use my Windows 7 Professional as client. JRE 7 is updated to the last version.
Can someone replicate my problem and help me?
TestBug_2014-10-07_1323.proj (8.91 KB)
