I have an issue with one of our plant ignition installs
Ignition Version 7.8.1 with OEE & SPC Running on Win Server 2008 R2 Java 8 Rel 40
Client OS Win 7 updated & Patched Monthly Running Java 8 Update 101
My issue is that after launching a client the client will eventually lock up and report gateway connection lost This may happen in 4 hours of launching or 12 hours or somewhere in between. There really is no sense of when it will happen. EDIT. After testing it seems to be related to having windows screen saver enabled.
When it does happen the whole PC is locked up and pretty much requires a reboot. EDIT: Mainly any widows service becomes non responsive along with anything that utilizes network services IE,Chrome,Lync,
Could this be a memory leak on the client side?
If i run a client locally on the GW all is fine.
Also I just updated java on the GW to 1.8 rel 101 and still same issue. Did not expect a fix as it seems it’s a client issue.
Any suggestions?
JP
