Sorry this took so long!
Here is this jstack log:
C:\Program Files\Java\jdk1.8.0_131\bin>jstack.exe -F 6648
Attaching to process ID 6648, please wait...
Debugger attached successfully.
Server compiler detected.
JVM version is 25.131-b11
Deadlock Detection:
No deadlocks found.
Thread 62: (state = BLOCKED)
- java.lang.Thread.sleep(long) @bci=0 (Compiled frame; information may be imprecise)
- sun.net.www.http.KeepAliveCache.run() @bci=3 (Compiled frame)
- java.lang.Thread.run() @bci=11 (Compiled frame)
Thread 61: (state = BLOCKED)
- java.lang.Object.wait(long) @bci=0 (Compiled frame; information may be imprecise)
- java.util.TimerThread.mainLoop() @bci=201 (Compiled frame)
- java.util.TimerThread.run() @bci=1 (Interpreted frame)
Thread 60: (state = BLOCKED)
- sun.misc.Unsafe.park(boolean, long) @bci=0 (Compiled frame; information may be imprecise)
- java.util.concurrent.locks.LockSupport.park(java.lang.Object) @bci=14 (Compiled frame)
- java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await() @bci=42 (Compiled frame)
- java.util.concurrent.LinkedBlockingQueue.take() @bci=29 (Interpreted frame)
- java.util.concurrent.ThreadPoolExecutor.getTask() @bci=149 (Compiled frame)
- java.util.concurrent.ThreadPoolExecutor.runWorker(java.util.concurrent.ThreadPoolExecutor$Worker) @bci=26 (Interpreted frame)
- java.util.concurrent.ThreadPoolExecutor$Worker.run() @bci=5 (Interpreted frame)
- java.lang.Thread.run() @bci=11 (Interpreted frame)
Thread 59: (state = BLOCKED)
Thread 58: (state = BLOCKED)
Thread 57: (state = BLOCKED)
Thread 56: (state = BLOCKED)
Thread 55: (state = BLOCKED)
Thread 54: (state = BLOCKED)
Thread 53: (state = BLOCKED)
- java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take() @bci=100 (Compiled frame)
- java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take() @bci=1 (Compiled frame)
- java.util.concurrent.ThreadPoolExecutor.runWorker(java.util.concurrent.ThreadPoolExecutor$Worker) @bci=26 (Compiled frame)
Thread 52: (state = BLOCKED)
- java.util.concurrent.locks.LockSupport.parkNanos(java.lang.Object, long) @bci=20 (Compiled frame)
- java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(long) @bci=78 (Compiled frame)
- java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take() @bci=124 (Compiled frame)
Thread 51: (state = BLOCKED)
Thread 50: (state = BLOCKED)
Thread 49: (state = BLOCKED)
- java.lang.Object.wait() @bci=2 (Compiled frame)
- java.util.TimerThread.mainLoop() @bci=28 (Compiled frame)
Thread 48: (state = BLOCKED)
Thread 47: (state = BLOCKED)
Thread 46: (state = BLOCKED)
Thread 45: (state = BLOCKED)
Thread 44: (state = BLOCKED)
Thread 43: (state = BLOCKED)
Thread 42: (state = BLOCKED)
Thread 41: (state = BLOCKED)
- java.lang.Object.wait(long) @bci=0 (Interpreted frame)
- java.lang.Object.wait() @bci=2 (Interpreted frame)
- com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryQueue.take() @bci=27, line=620 (Interpreted frame)
- com.inductiveautomation.factorypmi.application.gateway.QueryManager$UpdateQueryExecutor.run() @bci=52, line=422 (Interpreted frame)
Thread 40: (state = BLOCKED)
Thread 39: (state = BLOCKED)
Thread 38: (state = BLOCKED)
- com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run() @bci=38, line=293 (Interpreted frame)
Thread 37: (state = BLOCKED)
Thread 36: (state = BLOCKED)
Thread 35: (state = BLOCKED)
Thread 34: (state = BLOCKED)
Thread 33: (state = BLOCKED)
Thread 32: (state = BLOCKED)
Thread 31: (state = BLOCKED)
- java.util.TimerThread.mainLoop() @bci=28 (Interpreted frame)
Thread 30: (state = BLOCKED)
Thread 29: (state = BLOCKED)
- com.inductiveautomation.ignition.client.images.ImageLoader$CacheMaintainer.run() @bci=3, line=539 (Interpreted frame)
Thread 28: (state = BLOCKED)
Thread 27: (state = BLOCKED)
- com.inductiveautomation.ignition.client.launch.steps.CacheStep$IDKeepalive.run() @bci=12, line=231 (Interpreted frame)
Thread 1: (state = BLOCKED)
Thread 25: (state = IN_JAVA)
- java.lang.String.toLowerCase() @bci=4 (Compiled frame; information may be imprecise)
- com.inductiveautomation.ignition.common.AbstractDataset.getColumnIndex(java.lang.String) @bci=5, line=75 (Compiled frame)
- com.inductiveautomation.ignition.common.AbstractDataset.getValueAt(int, java.lang.String) @bci=2, line=160 (Compiled frame)
- com.inductiveautomation.factorypmi.application.components.tabstrip.TabAttribute.getInt(int, com.inductiveautomation.ignition.common.Dataset) @bci=59, line=86 (Compiled frame)
- com.inductiveautomation.factorypmi.application.components.tabstrip.TabComponent.addLabel() @bci=105, line=249 (Compiled frame)
- com.inductiveautomation.factorypmi.application.components.tabstrip.TabComponent.propertyChange(java.beans.PropertyChangeEvent) @bci=215, line=165 (Compiled frame)
- java.beans.PropertyChangeSupport.fire(java.beans.PropertyChangeListener, java.beans.PropertyChangeEvent) @bci=27 (Compiled frame)
- java.beans.PropertyChangeSupport.firePropertyChange(java.beans.PropertyChangeEvent) @bci=77 (Compiled frame)
- java.beans.PropertyChangeSupport.firePropertyChange(java.lang.String, java.lang.Object, java.lang.Object) @bci=31 (Compiled frame)
- java.awt.Component.firePropertyChange(java.lang.String, java.lang.Object, java.lang.Object) @bci=55 (Compiled frame)
- com.inductiveautomation.factorypmi.application.components.tabstrip.PMITabStrip.setSelectedTab(java.lang.String) @bci=102, line=497 (Compiled frame)
- com.inductiveautomation.factorypmi.application.components.tabstrip.PMITabStrip.setTabData(com.inductiveautomation.ignition.common.Dataset) @bci=43, line=556 (Compiled frame)
- sun.reflect.GeneratedMethodAccessor106.invoke(java.lang.Object, java.lang.Object) @bci=40 (Compiled frame)
- sun.reflect.DelegatingMethodAccessorImpl.invoke(java.lang.Object, java.lang.Object) @bci=6 (Compiled frame)
- java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object) @bci=56 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget() @bci=217, line=320 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.updateTarget() @bci=6, line=215 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(com.inductiveautomation.ignition.common.model.values.QualifiedValue) @bci=37, line=264 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.eval(com.inductiveautomation.ignition.common.Dataset) @bci=327, line=184 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.eval() @bci=7, line=121 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter.access$000(com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter) @bci=1, line=30 (Compiled frame)
- com.inductiveautomation.factorypmi.application.binding.CellUpdateAdapter$1.run() @bci=4, line=207 (Compiled frame)
- com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run() @bci=110, line=113 (Compiled frame)
- java.awt.event.InvocationEvent.dispatch() @bci=47 (Compiled frame)
- java.awt.EventQueue.dispatchEventImpl(java.awt.AWTEvent, java.lang.Object) @bci=21 (Compiled frame)
- java.awt.EventQueue.access$500(java.awt.EventQueue, java.awt.AWTEvent, java.lang.Object) @bci=3 (Compiled frame)
- java.awt.EventQueue$3.run() @bci=32 (Compiled frame)
- java.awt.EventQueue$3.run() @bci=1 (Compiled frame)
- java.security.AccessController.doPrivileged(java.security.PrivilegedAction, java.security.AccessControlContext) @bci=0 (Compiled frame)
- java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(java.security.PrivilegedAction, java.security.AccessControlContext, java.security.AccessControlContext) @bci=18 (Compiled frame)
- java.awt.EventQueue.dispatchEvent(java.awt.AWTEvent) @bci=46 (Compiled frame)
- java.awt.EventDispatchThread.pumpOneEventForFilters(int) @bci=245 (Compiled frame)
- java.awt.EventDispatchThread.pumpEventsForFilter(int, java.awt.Conditional, java.awt.EventFilter) @bci=35 (Compiled frame)
- java.awt.EventDispatchThread.pumpEventsForHierarchy(int, java.awt.Conditional, java.awt.Component) @bci=11 (Interpreted frame)
- java.awt.EventDispatchThread.pumpEvents(int, java.awt.Conditional) @bci=4 (Interpreted frame)
- java.awt.EventDispatchThread.pumpEvents(java.awt.Conditional) @bci=3 (Interpreted frame)
- java.awt.EventDispatchThread.run() @bci=9 (Interpreted frame)
Thread 24: (state = IN_JAVA)
- javax.swing.TimerQueue.run() @bci=20 (Compiled frame; information may be imprecise)
Thread 23: (state = IN_NATIVE)
- sun.awt.windows.WToolkit.eventLoop() @bci=0 (Interpreted frame)
- sun.awt.windows.WToolkit.run() @bci=58 (Interpreted frame)
Thread 22: (state = BLOCKED)
- sun.awt.AWTAutoShutdown.run() @bci=32 (Interpreted frame)
Thread 21: (state = BLOCKED)
- java.lang.ref.ReferenceQueue.remove(long) @bci=59 (Compiled frame)
- java.lang.ref.ReferenceQueue.remove() @bci=2 (Compiled frame)
- sun.java2d.Disposer.run() @bci=3 (Compiled frame)
Thread 14: (state = BLOCKED)
Thread 13: (state = BLOCKED)
Thread 12: (state = BLOCKED)
- java.lang.ref.Finalizer$FinalizerThread.run() @bci=36 (Compiled frame)
Thread 11: (state = BLOCKED)
- java.lang.ref.Reference.tryHandlePending(boolean) @bci=54 (Compiled frame)
- java.lang.ref.Reference$ReferenceHandler.run() @bci=1 (Compiled frame)
It seems it didn't detect a deadlock, so I'm assuming it didn't quite work right? The client was left online after 5 days. It was using 1,150 MB's of ram and is allowed to use 2.
