having a client that isn’t wanting to start this morning.
The client displays a popup that looks like this:
The last error in the launch error text file is:
Launch failed on step "StartupStep" with error:
java.net.ConnectException: Address already in use: no further information
at java.net.http/jdk.internal.net.http.HttpClientImpl.send(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientFacade.send(Unknown Source)
at com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook.downloadProjectInitDescriptor(ClientLaunchHook.java:444)
at com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook.setup(ClientLaunchHook.java:226)
at com.inductiveautomation.ignition.client.launch.steps.StartupStep.run(StartupStep.java:108)
at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33)
Caused by: java.net.ConnectException: Address already in use: no further information
at java.net.http/jdk.internal.net.http.common.Utils.toConnectException(Unknown Source)
at java.net.http/jdk.internal.net.http.PlainHttpConnection$ConnectEvent.handle(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.handleEvent(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.lambda$run$3(Unknown Source)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at java.net.http/jdk.internal.net.http.HttpClientImpl$SelectorManager.run(Unknown Source)
Caused by: java.net.BindException: Address already in use: no further information
at java.base/sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)
at java.base/sun.nio.ch.SocketChannelImpl.finishConnect(Unknown Source)
... 5 more
Any ideas? This is a kiosk type of client, so at the moment no rush.
