Client Screen Locked Popup
I'm trying to figure out why I keep getting the "Screen Locked - This screen has been locked by " popup in my client:
I do not have Inactivity Enabled in my Project Properties and I've searched everywhere in the Forum and throughout my Gateway. Can someone guide me to where I can disable this or at least increase the timer b/c it is constantly locking up my client as I'm developing the project. I apologize if this is something simple - I'm still getting the hang of Ignition. Thank you in advance!
what's egan1 ?
The Username
Is there something special Egan1 was doing when this happen ?
disclaimer: I've never used vision and never seen this popup, I'm just trying to think about what I'd throw my eyeballs at if I were in your situation.
No, the client is sitting dormant while I'm developing at the same time. As I save changes, the Client is refreshing and updating, but then it locks up all of a sudden. Not sure what causes it. Maybe too many changes on my side? Or Property change?
Does this look like it could help ?
edit: actually this looks like it's related to an inactivity timer which you said you don't have. But maybe it's something else ?
Do you need to relog afterward ?
Are you doing anything with access rights when developing ?
YES! That was it. Thank you so much! I didn't add it, but the Project Template I used must have had it. How infuriating! Thanks again!
Glad I could help :slight_smile:
Hello Pascal, This solution is not working for me...I'm having the same situation and tried to follow your instructions to solve, but I have no settings for Client Timer Scripts. Its blank. Any idea?
This is not a configuration window. You need to create a script to have anything appear.
See the + icon at the bottom ?
Pascal what I'm trying to show is that I'm having the screen lock issue as described by avidsolutions13, but I don't have any script in the client timer script...so once I have nothing there, what should be another possible cause for getting my client screen lock? Does it make sense?
I'm talking about the solution based on this instruction
Not a clue, I'm sorry.
Thanks in anyway Pascal!
Anyone from @SCADASupport to help me with this question?
This forum is not support. Use https://support.inductiveautomation.com/
You can try opening your project and using the Find/Replace feature (CTRL+F) to look for any script containing system.security.lockScreen. The person who created the project might have some script hidden somewhere like in the Header with a timer component that calls this function.
Thanks Leonardo! Muito obrigado!
You're welcome Fabiano! De nada!
