my Client Tags folder is magically disappeared!
the console doesn’t give any client tag error, but in every project i can’t see any client tag… what happened?!
What version of Ignition are you using? I am assuming 7.5. There is a known issue in this version where the client tags folder will disappear. If you refresh the SQL Tags Browser the folder should display again. We are aware of the problem and are working to correct it.
fixed. thanks ![]()
using 7.9.10
I haven’t been logged into the server for a few weeks. I was called by a client that said the display was broken. so i looked into it and a complete folder is missing along with all the tags.
