Hi guys,
I have to try to get the client login username display in reporting.
Found the below error.
Any idea?
Thanks,
Priyanka
Report work in gateway scope, you can't read Client scope tags.
@m.pelagatti Thanks for the quick response.
Any idea how to display the client login name in the report?
You can delete default value expression , and bind userName with client tag, in reportViewer component, i think will work
In other words, create a user name parameter in the report. Supply that parameter from client scope.
