In a situation where the same project is deployed on several gateways, I am looking for a way to see if they are running the same version. Is there a way to get to last build/deploy date or edit count or something like that from script ?
Bo
Bo
The first thought that I have is if you have auditing enabled you could write a sql query against the audit log. You could do something like this on a query tag, or, sql binding
SELECT
count(*)
FROM
audit_events
WHERE
action = 'project publish' and
originating_system = 'project=test'
