Client Vision Login and password problem
Were I can set Username and Password to access to Client Vision ?
I have put them in the project properties, but Client Vision dont read it
In the gateway configuration, there are User sources, which Ignition use for security.
You have to configure that first:
Ignition comes with one, Default user source. You can edit that or create your own new user source…
First, you create Roles, then Users…
Hi, Anton
To be the great programmer maybe is a great thing, but to be a great person it is much more.
Thank you wery much for you reply, was wery useful for me. The problem solved
Best regards
Sergey
