I have been working on an overview in the designer and it seems that when I open the client there are alignment issues. Attached you will see the difference in the two windows I have created. The screenshot of the designer you will see everything perfectly aligned. Then when I open the client you will see that everything is shifted to the left is seems. Any chance someone could help me resolve this issue, I am new to the designer so it may be a simple fix.
Are the Layout constraints for the items and the conveyor sections the same? (Right-click on each item and select ‘Layout’ to check.) Are you moving the position of the items? If so, how are you doing that?
That worked! thank you so much!
