Closing initial pop-up upon on second pop-up populate
I have implemented 'Save' button. On clicking on it, i am opening small pop-up. In this small pop-up, i have implemented OK button upon clicking which i am opening bigger pop-up. Question is that, on opening on bigger pop-up, how we can close the small one.
Actually, the real question is:
Vision or Perspective?
Its perspective.
If you're opening the pop-up through the "Event Configuration" window, make note of the "Identifier" value. Then, you can close the pop-up in a different Popup action by typing in the same Identifier.
It is applicable in parametrized pop-up also.
The parameters of the Popup do not matter. All you care about is the identifier (id) in use for the "first" Popup. This value must be passed to the "second" Popup. The second Popup must take the action to close the first Popup, OR it can send a page-scoped message - which the first Popup must be listening for.
system.perspective.closePopup(id="MyFirstPopupId")
system.perspective.closePopup(id="MySecondPopupId")
or
# requires the first popup have a configured message listener which invokes code to close the popup.
system.perspective.sendMessage("CLOSE_POPUP", payload={"id": "MyFirstPopupId"}, scope="page")
