We are using version 8.1.28, and for some time today, we have been seeing errors like the following. At the same time, almost all scripts in the Gateway event scripts report the same error, but they can be executed normally in the Designer's script console.:
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 1, in NameError: name 'ClockDriftDetector' is not defined
at org.python.core.Py.NameError(Py.java:261)
at org.python.core.PyFrame.getname(PyFrame.java:257)
at org.python.pycode._pyx106564.f$0(:1)
at org.python.pycode._pyx106564.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:803)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:823)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:751)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:804)
at com.inductiveautomation.ignition.common.script.TimerScriptTask.run(TimerScriptTask.java:90)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: org.python.core.PyException: NameError: name 'ClockDriftDetector' is not defined
... 18 common frames omitted
There were no abnormal entries in the gateway logs during this time, and nobody saved the project. After about half an hour, it automatically recovered.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 21, in File "", line 171, in finishModuleArray AttributeError: 'com.inductiveautomation.ignition.common.script.Pro' object has no attribute 'finishDataAppend'
at org.python.core.Py.AttributeError(Py.java:178)
at org.python.core.PyObject.noAttributeError(PyObject.java:965)
at org.python.core.PyObject.__getattr__(PyObject.java:959)
at org.python.pycode._pyx112656.finishModuleArray$1(:37)
at org.python.pycode._pyx112656.call_function()
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:416)
at org.python.pycode._pyx106231.f$0(:21)
at org.python.pycode._pyx106231.call_function()
at com.inductiveautomation.ignition.common.script.TagChangeScriptExecutor$TagChangeExecutionCallback.execute(TagChangeScriptExecutor.java:242)
at com.inductiveautomation.ignition.common.script.TagChangeScriptExecutor$TagChangeExecutionCallback.execute(TagChangeScriptExecutor.java:194)
at com.inductiveautomation.ignition.common.util.SerialExecutionQueue$PollAndExecute.run(SerialExecutionQueue.java:102)
Caused by: org.python.core.PyException: AttributeError: 'com.inductiveautomation.ignition.common.script.Pro' object has no attribute 'finishDataAppend'
... 25 common frames omitted
