Code signing certificate SSL.com
I'm looking into getting starting with the Ignition SDK modules which requires a Code Signing Certificate in order to use the module in a production environment.
The Module will be for internal use only at this moment.
Buy Code Signing Certificates - SSL.com Is this the right option withouth the "eSigner Tier" and " Yubikey" and can i actually retrieve the private key?
In order to purchase any Certificate within the company i need confirmation that it will work.
Module signing is pretty meaningless, there is no real advantage to using a publicly trusted certificate for signing Ignition modules.
Just have your company generate a certificate from their CA or use a self-signed certificate.
That's indeed correct, Thanks.
