Code snippets within documents like MS Word
Not Ignition related, what do you use for inserting code snippets into documents, like Word? Copy as plain text, HTML, as an image, etc.?
I like to use www.hilite.me
Thanks, looks similar to this site I have used before, Online syntax highlighting for the masses!.
I will try the one you linked and see if it works better.
Yeah, I think ultimately as long as the destination is “a word document” a static syntax highlighter of some kind is probably the best approach. Depending on your Word version, there’s probably plugins of varying levels of quality available.
