Hello, I am trying to connect to my codesys OPC server without success so far.
I am using the Ignition OPC-COM and use Matrikon’s Explorer to verify that i can read tags and its works.
Follow the log
java.lang.IllegalStateException: The server did not indicate that it was ready to receive connections.
at com.inductiveautomation.opccom.COMServerImpl$3.run(COMServerImpl.java:476)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
7.9.10 (b2018112821)
Oracle Corporation 1.8.0_121
Thanks!
