Color Array Parameters SDK
Hello, i want to add a “Color Array” parameter inside my component. I didn’t know wich type of variable I need to declare in my java class. By exemple, their is a Color Array parameter in the Pie Chart object of Ignition Designer.
I’m adding the parameter with :
Code:
public [Type of Variable] Data;
getData()
setData(…)
addProp(“data”, “Data”, “”, CAT_DATA); //into CommonBeanInfo
Thanks !
Putting the following code on mouseClicked for a Button in the same Root Container as the Pie Chart prints out the following in the console.
object = event.source.parent.getComponent('Pie Chart')
print object.getSectionColors()
array(java.awt.Color, [java.awt.Color[r=255,g=85,b=85], java.awt.Color[r=85,g=85,b=255], java.awt.Color[r=85,g=255,b=85], java.awt.Color[r=255,g=85,b=255], java.awt.Color[r=85,g=255,b=255], java.awt.Color[r=255,g=175,b=175], java.awt.Color[r=128,g=128,b=128]])
The datatype for this is ‘array.array’
The datatype you’re looking for is exactly what it appears to be, an array of colors.
private Color [] myArrayOfColorsProperty;
Square brackets signify that it’s an array. For more on arrays:https://docs.oracle.com/javase/tutorial/java/nutsandbolts/arrays.html.
