Hi Ignition Community,
I have configured an XY chart to function as a Gantt chart, following the guidelines provided in the manual. However, I am encountering an issue where all the blocks in the Gantt chart appear to be the same color.
I would appreciate any assistance in resolving this color configuration problem.
Thank you!
Here's the json of the chart,
"type": "ia.chart.xy",
"version": 0,
"props": {
"legend": {
"enabled": false
"cursor": {
"enabled": false,
"series": "mySeries",
"lineX": {
"enabled": false
"lineY": {
"enabled": false
"scrollBars": {
"horizontal": {
"enabled": false,
"vertical": {
"enabled": false
"xAxes": [
"name": "time",
"label": {
"enabled": true,
"text": "Time",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "date",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "M/d/yyyy"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"verticalCenter": "middle",
"horizontalCenter": "middle"
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 60,
"position": 0.5
"font": {
"size": "",
"weight": 500
"yAxes": [
"name": "Operator",
"label": {
"enabled": false,
"text": "Process Temp",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "category",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": null,
"position": 0
"font": {
"size": "",
"weight": 500
"series": [
"name": "mySeries",
"label": {
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "example",
"x": "toDate",
"y": "name"
"xAxis": "time",
"yAxis": "Operator",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{fromDate} - {toDate}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "column",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "fromDate",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"width": null,
"height": null,
"fill": {
"color": "color",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": false,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"dataSources": {}
"meta": {
"name": "XYChart_3"
"position": {},
"custom": {},
"propConfig": {
"props.dataSources.example": {
"binding": {
"type": "query",
"config": {
"returnFormat": "json",
"queryPath": "Axcend/ScheduleShifts/getShiftTemplateDataWithColor",
"parameters": {
"templateID": "26"
]type or paste code here
Here's the data which im using,
"example": [
"fromDate": "1899-12-30 07:00:00",
"toDate": "1899-12-30 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1899-12-30 19:00:00",
"toDate": "1899-12-30 07:00:00",
"color": "#000080",
"name": "Shift"
"fromDate": "1899-12-31 07:00:00",
"toDate": "1899-12-31 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1899-12-31 19:00:00",
"toDate": "1899-12-31 07:00:00",
"color": "#000080",
"name": "Shift"
"fromDate": "1900-01-01 07:00:00",
"toDate": "1900-01-01 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1900-01-01 19:00:00",
"toDate": "1900-01-01 07:00:00",
"color": "#000080",
"name": "Shift"
"fromDate": "1900-01-02 07:00:00",
"toDate": "1900-01-02 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1900-01-02 19:00:00",
"toDate": "1900-01-02 07:00:00",
"color": "#000080",
"name": "Shift"
"fromDate": "1900-01-03 07:00:00",
"toDate": "1900-01-03 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1900-01-03 19:00:00",
"toDate": "1900-01-03 07:00:00",
"color": "#000080",
"name": "Shift"
"fromDate": "1900-01-04 07:00:00",
"toDate": "1900-01-04 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1900-01-04 19:00:00",
"toDate": "1900-01-04 07:00:00",
"color": "#000080",
"name": "Shift"
"fromDate": "1900-01-05 07:00:00",
"toDate": "1900-01-05 19:00:00",
"color": "#00FFFF",
"name": "Shift"
"fromDate": "1900-01-05 19:00:00",
"toDate": "1900-01-05 07:00:00",
"color": "#000080",
"name": "Shift"
