Hi All,
Using the bar chart component I’m trying to change the colour of the bar when it exceeds a certain value (similar to the thermometer and meter components). I noticed within the bar chart property editor it doesn’t allow me to add an expression to the series colours. As an alternative I used the chart’s axis and placed a Level Indicator(As I could change the colour property with an expression for this component) over the chart area where the bar should be present. The problem with this solution is the alignment varies as the screen size changes and therefore looses its correct appearance.
Does anybody have any other ideas?
Thanks,
Gavin
