I am creating dynamic multistate buttons by setting the state property.
There appears to be a bug where if you use a colur tuple it throws an error on initialising (below), but once this has been thrown it works from then on in properly.
You cannot catch this error with a try/except.
If you however pass it a java.awt color object it works as expected.
eg
from java.awt import Color
bg=Color(128,128,128,255) #works
fg=(0,0,0,255) #throws error once on initialising
Details of erro:
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error invoking PyTuple.add(0)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:81)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$ParseContext.onElementEnd(XMLDeserializer.java:663)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:165)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.readElement(BinaryParser.java:157)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.BinaryParser.parse(BinaryParser.java:51)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserializeBinary(XMLDeserializer.java:313)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:233)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:277)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:216)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:435)
at com.inductiveautomation.factorypmi.application.FPMIApp$RuntimeWindowOpener.openWindow(FPMIApp.java:1555)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:924)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:916)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$1.run(NavUtilities.java:201)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:611)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapWindow(NavUtilities.java:199)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:111)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.swapTo(NavUtilities.java:92)
at com.inductiveautomation.factorypmi.application.components.tabstrip.PMITabStrip.setSelectedTab(PMITabStrip.java:426)
at com.inductiveautomation.factorypmi.application.components.tabstrip.TabHolderPanel.mousePressed(TabHolderPanel.java:188)
at java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:279)
at java.awt.Component.processMouseEvent(Component.java:6502)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3311)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4489)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:68)
… 64 more
Caused by: java.lang.UnsupportedOperationException
at org.python.core.PyTuple.add(PyTuple.java:361)
… 69 more
Ignition v7.6.4-rc3 (b2013110714)
Java: Oracle Corporation 1.7.0_51
