Column indexing error on 8.0 but works on 8.1
Hi all,
I am having issues with with using [-1] in my projectlibrary script on a server with Ignition 8.0.14, but it works perfectly fine on another server with Ignition 8.1.1.
Down below is relevant examples of the code with regards to the issue:
table_batch = system.db.runQuery(general_query % lastrow, db_name)
table_batch = system.dataset.toPyDataSet(table_batch)
column_index = table_batch.getColumnIndex(“LASTROW”)
new_lastrow = table_batch[-1][column_index]
When I change the [-1] to a [0] it works fine on this server, but we would like to have it as [-1]
Best regards,
Benjamin
IIRC, v8.1 greatly improved the PyDataset's emulation of PyList. So no, you'll need to upgrade.
It is a bit crazy to stay on an EOL version, too. See this discussion:
Thanks a lot for the answer :slight_smile:
I will go ahead and start the upgrade then!
Best regards,
Benjamin
