This is everything when I select full in the alarm window.
com.inductiveautomation.ignition.common.xmlserialization.SerializationException: Error invoking [ColumnSelectorPanel]com.inductiveautomation.factorypmi.plugins.reporting.components.ColumnSelectorPanel[Column Selector,263,636,714x172,invalid,layout=javax.swing.ScrollPaneLayout$UIResource,alignmentX=0.0,alignmentY=0.0,border=javax.swing.border.TitledBorder@7ad4cdd4,flags=328,maximumSize=,minimumSize=,preferredSize=java.awt.Dimension[width=714,height=172],columnHeader=,horizontalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.incors.plaf.alloy.AlloyScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.BorderUIResource$EmptyBorderUIResource@75baec8e,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=HORIZONTAL,unitIncrement=1],horizontalScrollBarPolicy=HORIZONTAL_SCROLLBAR_AS_NEEDED,lowerLeft=,lowerRight=,rowHeader=,upperLeft=,upperRight=,verticalScrollBar=javax.swing.JScrollPane$ScrollBar[,0,0,0x0,invalid,layout=com.incors.plaf.alloy.AlloyScrollBarUI,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.BorderUIResource$EmptyBorderUIResource@75baec8e,flags=4194664,maximumSize=,minimumSize=,preferredSize=,blockIncrement=10,orientation=VERTICAL,unitIncrement=1],verticalScrollBarPolicy=VERTICAL_SCROLLBAR_AS_NEEDED,viewport=javax.swing.JViewport[,0,0,0x0,invalid,layout=javax.swing.ViewportLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=25165832,maximumSize=,minimumSize=,preferredSize=,isViewSizeSet=false,lastPaintPosition=,scrollUnderway=false],viewportBorder=].setHGap(2)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:81)
at com.inductiveautomation.factorypmi.application.xmlserialization.ComponentDeserializationHandler.endSubElement(ComponentDeserializationHandler.java:84)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer$Parser.endElement(XMLDeserializer.java:475)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer._deserialize(XMLDeserializer.java:201)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:164)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.XMLDeserializer.deserialize(XMLDeserializer.java:160)
at com.inductiveautomation.factorypmi.application.model.WindowCache._deserializeWindow(WindowCache.java:276)
at com.inductiveautomation.factorypmi.application.model.WindowCache._loadWindow(WindowCache.java:217)
at com.inductiveautomation.factorypmi.application.model.WindowCache.openWindow(WindowCache.java:430)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:895)
at com.inductiveautomation.factorypmi.application.FPMIApp.openWindow(FPMIApp.java:872)
at com.inductiveautomation.factorypmi.designer.model.ObjectHolder.openWindow(ObjectHolder.java:3710)
at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.onDoubleClick(WindowNode.java:439)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener$1.run(NavTreePanel.java:513)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.deserialization.handlers.ObjectDeserializationHandler.endSubElement(ObjectDeserializationHandler.java:68)
… 31 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.factorypmi.plugins.reporting.components.ColumnSelectorPanel$CheckBoxPanel.createGUI(ColumnSelectorPanel.java:393)
at com.inductiveautomation.factorypmi.plugins.reporting.components.ColumnSelectorPanel$CheckBoxPanel.recreateGUI(ColumnSelectorPanel.java:382)
at com.inductiveautomation.factorypmi.plugins.reporting.components.ColumnSelectorPanel.setHGap(ColumnSelectorPanel.java:216)
… 36 more
Ignition v7.1.6 (b5739)
Java: Sun Microsystems Inc. 1.6.0_20
