Hello,
I’m trying to convert a legacy Driver from v7.9 to v8 and im getting the following Java error after installing the driver in Ignition v8 Gateway.
I realize that the class “com.inductiveautomation.xopc.driver.api.configuration.DriverType” cannot be loaded due to the changes made with the newer version however I don’t know how to get around this without rewriting my entire driver. i’m hoping there’s a 1:1 class that i can remap to but i’m sure its not that easy.
I’ve hunted trough the new programming guide supplied for v8 but haven’t had any luck yet.
Any help would be greatly appreciated!!
com.inductiveautomation.ignition.common.modules.ModuleLoadException: Unable to load hook class “”.
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.loadHook(ModuleManagerImpl.java:2299)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.load(ModuleManagerImpl.java:1994)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1164)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$2.call(ModuleManagerImpl.java:733)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:905)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.installModuleInternal(ModuleManagerImpl.java:695)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$InstallCommand.execute(ModuleManagerImpl.java:1851)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$Receiver.receiveCall(ModuleManagerImpl.java:1801)
at com.inductiveautomation.ignition.gateway.redundancy.QueueableMessageReceiver.receiveCall(QueueableMessageReceiver.java:47)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.dispatchMessage(RedundancyManagerImpl.java:813)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask.run(RedundancyManagerImpl.java:849)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:518)
Caused by: java.lang.NoClassDefFoundError: com/inductiveautomation/xopc/driver/api/configuration/DriverType
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(Unknown Source)
at java.base/java.security.SecureClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader$1.run(Unknown Source)
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at driver.GatewayHook.(GatewayHook.java:22)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.base/java.lang.Class.newInstance(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.loadHook(ModuleManagerImpl.java:2279)
… 17 more
Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.xopc.driver.api.configuration.DriverType
… 34 more
8.0.2 (b2019060511)
Azul Systems, Inc. 11.0.3
