System info: Ignition 7.5.3 and Reporting module 1.5.0
I was wondering if it is possible to combine 2 different page layouts in the same report when using the reporing module.
Thanks.
Thanks.
What exactly are you trying to accomplish?
I want the first page to have a portrait layout. The following pages should be have a landscape layout. Is that combination possible in one report.
You can’t change the orientation of each page since the setting is global. However, you can make certain pages horizontal rather than vertical by rotating all of the components on that page. For example, you can select a table component and click on the Ruler button at the bottom right of the designer. You can then click on the Roll/Scale tab and rotate the table. Hope this helps accomplish what you want.
