Hi all, I am trying to create a roster which contains the users of three other rosters and i only require this new roster for a notification block. I am asked to make a notification pipeline for medium level alarms but different operators are to be called upon based on the machines. so I have to create 10 different rosters in total if I want to achieve this but i can do this if i am able to merge the existing rosters together and return the merged roster to the notification block. Is there any ways to do that ?
You can dynamically produce any desired roster using a "calculated" roster. It is just a script that yields the contacts to use at that moment.
But I want to get the contacts from the roster so that in the future if i have to change a personnel I should only have to edit the roster. Is this possible with calculated roster?
Your code has a lot of problems.
Chiefly:
- You're not returning the contact infos as a list of possible contact infos
- You're not differentiating between SMS, email, or phone numbers, which you would want to do.
- You don't need to call
system.user.getUserif you usesystem.roster.getRoster(), which directly returnsUserobjects - Hardcoding in
defaultto thesystem.user.getUserfunction is also a bad idea. - You're returning in the wrong format anyways: you're returning something like:
{ "Maintenance Roster": [
{ "joe": [contactInfo] }
But you need to return a direct list of user-like objects; see the manual:
https://docs.inductiveautomation.com/display/DOC81/Notification+Block#NotificationBlock-Calculated
A generic mergeRosters suitable for use in a calculated roster script would be something like this:
def mergeRosters(*rosterNames):
return [
dict(username = user.get(user.Username), **{ci.contactType: ci.value for ci in user.contactInfo})
for rosterName in rosterNames
for user in system.roster.getRoster(rosterName).users
return mergeRosters("day shift", "night shift")
I tried this code like u said it returned an error in gateway log :
java.lang.ClassCastException: class java.lang.String cannot be cast to class java.util.List (java.lang.String and java.util.List are in module java.base of loader 'bootstrap')
def calculateRoster(event, builder):
return [
for user in system.roster.getRoster({rosterName}).users
[userList] = mergeRosters(['TEST', 'TEST2'])
return userList
You're not calling it correctly. Look at the code I posted, and compare it to yours:
return userList
You're unnecessarily wrapping the return value in a list, and you're unnecessarily wrapping the input value to the function in a list.
I made the corrections as u said and now the error displays :
org.python.core.PyException: TypeError: getRoster(): 1st arg can't be coerced to String
return [
userList = mergeRosters("TEST", "TEST2")
return userList
That's still not the code I gave you; why are you wrapping rostername in curly braces? That's making a set.
Sorry about that, now when I take off the curly braces it seems to return an error like :
i have also posted the code i used again please do tell me if there is anything wrong with the script.
return [
return mergeRosters("TEST", "TEST2")
Is the indentation like this in your script, or did the copy-paste mess it up ?
return [
dict(username = user.get(user.Username), **{ci.contactType: [ci.value] for ci in user.contactInfo})
Think I was missing one set of square brackets, to put the contact infos into a list.
thank you the script now works and sends emails with the combined roster
