Combining bits from DINTs to create Status Integers in Ignition
I have an idea how to do something, but I don't know which path to explore to figure out how to accomplish it. Here is the idea:
I have 2 DINTs that have 32 Running, and Failed bits, from 32 devices. I'd like to combine the two in Ignition to use in a "Multi-State Indicator" (and avoid adding 32 Dints from the PLC with the combined value). Three states would be displayed: Failed, Running, Off.
I believe if a DINT is labeled "Running", I can access the individual bits by adding a period... i.e. Running.0. Is that correct?
Then I would create an integer in Ignition that had something like an "If" function...
If Failed.0, then Status = 2, elseif Running.0, then Status = 1, else Status = 0. (No idea of the syntax, or where to even enter it.)
I have no idea how to even look this up to figure it out. There may be an easier way to accomplish this, but I just don't have enough experience with Ignition to see it. I just don't want to add 32 DINTs from the PLC to make this happen. Can you at least point me in the right direction?
Supply each pair of bits to the binEnc() expression function. Yields 0, 1, 2, 3 for two booleans.
I'm back at the customer's today, and I can't wait to try that out. That's going to be useful. Thank you so much.
