Combining Current Time and Minutes Left
Im trying to create a datetime tag that combines a current time tag and a float tag with "minutes left" together. I am basically trying to figure out a production end time based on a end goal and an average done per hour.
Right now i have a tag that displays currentTime and I have a tag that displays minutesLeft. In stupid terms I just need to add currentTime+minutesLeft and have it output in dateTime format.
I know there is system.date.addMinutes(X,X) however I need to use a tag value that is constantly changing for the second argument in addMinutes.
Any ideas?
There is a corresponding expression function you can use in an expression binding (or expression tag):
The Syntax is add*(date, value)
For the Value argument how can I use a tag path in there?
addMinutes(now(5000), {[default]MinutesLeft})
Minutes left
  1. Pick the function.
  2. Pick the tag.
now(5000) causes the expression to reevaluate every 5000 ms. Adjust to suit.
Something like
addMinutes({path/to/now}, {path/to/forecastMinutes})
Got it, appreciate the help guys.
Good. Don't forget to mark one of the answers as "Solution".
How can I format the label to only show the time like I have the tag formatted? Its showing the date first then the time. I have the tag I want to display formatted with h:mm aa and thats also how I want the label on the page to show but i dont see any formatting options for it.
dateFormat(
	addMinutes(now(5000), {[default]MinutesLeft}),
	'h:mm aa'
If you had pressed (1) in my image above you should have been able to find it. See Expression Functions | Ignition User Manual for the docs.
