Is there a way to combine all my projects for each piece of equipment in to one major plant wide project?
A variety of things can be done.
You can import all your projects into one project. Importing a project into another project can be done from the Ignition Designer: File -> Import
If you are working with a number of the same kind of equipment then it is often good to use templates: docs.inductiveautomation.com/di … ate+Basics
It is good practice to create things in Ignition that can be reused, such as templates, popup windows, Python scripts.
You can create a project for navigating to other projects using retargeting: docs.inductiveautomation.com:84 … etargeting
Best,
