Comma decimal edit table cell turns to dot
I'm not sure whether this is a bug or an intended feature. I have a table column with decimal values that are correctly displayed using commas. However, when I double-click to edit a cell, the comma changes to a dot, and if I commit the value, it gets saved as an integer in SQL. What I want is for the value to still show the comma as the decimal separator when editing the cell. Is this possible?
What do you have the column render value set to? I would try setting it to string.
If I set it to string it always shows decimals with a dot. I'd rather see a comma in both the starting and editing cell... Anyways, if that's not possible your approach is alright as it's consistent.
You could instead use an embedded view with either a Text or Numeric Entry Field.
