Comment Panel highlighted red on client server
I'm working in the designer where gateway is hosted on a comment panel, but on my client it is red and the log says client is missing required permissions.
I am using a named query and I previously Enabled Legacy Database Access which fixed the issue however this cannot be a permanent fix and it creates security risks. Does anyone know of any alternative fixes to ensure the comment panel works appropriately in the client?
Your diagnosis indicates you still have a regular query binding where you need a named query binding. Look closer.
