Comments Panel adding unique itemid in itemnotes not working
i am using postgres with 3 tables. Everything works as expected when using the default insertnotes with the extension function insertnote disabled.
I have an additional column in the itemnotes table that is called itemid which is a varchar.
when i enable insertnote fuction with
def insertNote(self, note, filename, sticky):
	## Use this code to insert the entered note into your database table
	## fetch attachment data
	attachmentBytes = system.file.readFileAsBytes(filename)
	itemid = self.itemid
	## insert the note and attachment data
	query = "INSERT INTO notes (note, username, t_stamp, attachment, filename, sticky)" + \
			"VALUES (?, ?, CURRENT_TIMESTAMP, ?, ?, ?)"
	args = [note, system.security.getUsername(), attachmentBytes, filename, sticky]
	noteID = system.db.runPrepUpdate(query, args, database="", getKey=True)
	***query = "INSERT INTO itemnotes (itemid) VALUES (?)"***
***	args = [itemid]***
***	itemnotes = system.db.runPrepUpdate(query,args,database="")***
	## add an additional entry into a note/account mapping table
	## this second section is not needed if you are using only one table to store notes
	accountID = 1234 #fill in your account value here
	query = "INSERT INTO ItemNoteMapping (account_id, note_id) VALUES (?, ?)"
	args = [accountID, noteID]
	system.db.runPrepUpdate(query, args, database="", skipAudit=True)
I get this error
15:39:50.069 [AWT-EventQueue-0] ERROR Vision.Components.PMICommentsPanel2 -- Error invoking extension method.
org.python.core.PyException: java.lang.NullPointerException: java.lang.NullPointerException
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:192)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:208)
at org.python.core.PyObject.call(PyObject.java:461)
at org.python.core.PyObject.call(PyObject.java:465)
at org.python.pycode.pyx79.insertNote$1(:20)
at org.python.pycode.pyx79.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call
(PyFunction.java:474)
at org.python.core.PyFunction.call(PyFunction.java:469)
at org.python.core.PyFunction.call(PyFunction.java:459)
at org.python.core.PyFunction.call(PyFunction.java:454)
at com.inductiveautomation.vision.api.client.components.model.ExtensionFunction.invoke(ExtensionFunction.java:152)
at com.inductiveautomation.factorypmi.application.components.PMICommentsPanel2.addNewNote(PMICommentsPanel2.java:246)
at com.inductiveautomation.factorypmi.application.components.PMICommentsPanel2$AddNotePanel.actionPerformed(PMICommentsPanel2.java:670)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
at com.inductiveautomation.snap.swing.RibsEventQueue.dispatchEvent(RibsEventQueue.java:99)
Caused by: java.lang.NullPointerException: null
at java.base/java.io.File.(Unknown Source)
at com.inductiveautomation.ignition.common.script.builtin.FileUtilities.readFileAsBytes(FileUtilities.java:137)
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:190)
... 50 common frames omitted
I am just trying to add a unique id to the comment so it can be pulled for specific items instead of all the comments.
Any help would be greatly appreciated.
Thank you
filename will be None, Python's special singleton object representing null, if there was no attachment on the note. You need to handle that in your code.
I will try that.
Thank you
So i was able to get it tonwork but the noteid is not incrementing in the itemnotes datatable.
I am using the example excatly as shown just adding a 3rd argument in the itemnotes query called itemid that is a varchar.
Everything is working but the noteid no incrementing which is causing the dataset for data to not work properly since noteid is not changing
Thank you for your help
Do you have an autoincrementing primary key in your notes column?
Yes the id column is updating everytime a new note is added but the itemnotes noteid is not. When i use the default insertnote it works as expected but not when using the insertnote extension function.
