The comments panel is working as expected, I can save and delete notes.
When I set ‘attachments enabled’ to false I get the following error:
GatewayException: SQL error for “INSERT INTO NotesModificationsDone (NoteText, UserName, TimeStamp, Attachment, AttachmentName, IsSticky) VALUES (?, ‘thierry’, CURRENT_TIMESTAMP, CAST(? AS VARBINARY(MAX)), ?, ?)”: The value is not set for the parameter number 3.
caused by SQLServerException: The value is not set for the parameter number 3.
Ignition v7.5.6 (b1316)
Java: Oracle Corporation 1.7.0_21
When I use the comments panel and set the security settings to ‘Hide’ then this is working as expected.
When I set the security settings to ‘Disable events’ it doesn’t work. Every user can add notes…
