Hi to Everybody,
I should communicate with ignition with a AB Micrologix 1400 using the its standard ethernet port on the PLC.
When I define the device on Ignition, there is a parameter called “connection path”, what I must put inside this form for communicate with the Micrologix 1400.
Also, the driver supports the browsing of the tags?
Any suggestion is appreciated
Thank you very much
Andrea
