I have a 3rd party device that has an Ethernet I/P card. I wanted to find out if Ignition has a module with which I can communicate to this device. Any options?
Santosh
Santosh
@pturmel thrice in as many days?
Unless this device walks, talks, and quacks like a ControlLogix we do not have a driver for it.
You’ll need a 3rd party EtherNet/IP driver like Phil’s or to bring the I/O into a PLC we can talk to.
Please share more information about your device and I can help you figure out if it is supported. Sending me the EDS file is the normal place to start. My module supports the normal 2-hr trial mode, so if you have the device in hand, we can certainly get it running before you buy.
The device is a Kaiser Sigma 2 Compressor. It has an ethernet port standard that has access to its webserver. I have reached out to the supplier to get us the part number for the EIP card. I will send it once i have that information. If that does not work, then we might go the webserver route.
From manual I did not see Ethernet/IP module, but they do have ModbusTCP option.
