Communicating with Anybus Explict Messaging
I have a piece of equipment that I am trying to communicate with through ignition. According to the equipment manual, it is set up to do Explicit Message data format through an Anybus communicator 7072. What driver would I need to use to set up this communication?
Heres some additional information provided in the manual that may help:
Output Data class
Class: 176 (0x00B0)
Instance: 1
Service Code: GetAttributeSingle
Input data class
Class: 177 (0x00B1)
Instance: 1
Service Code: SetAttributeSingle, GetAttributeSingle
It also provides a table that has the Attribute and Bytes for each item
Example:
Attribute: 3 ,Bytes: 1 ,Item: Device operation ,contents: Indicates current device status
It sounds like you're describing generic EtherNet/IP messaging. Ignition does not have a built in driver for this, but @pturmel does have a 3rd party module available for sale that may support it.
Yes, my new client driver option supports this type of messaging since v2.1:
You will need to construct a supplemental XML configuration file that specifies the data types for each class/instance/attribute that you want to decode. Or leave unspecified to get byte arrays.
The Gateway is version 8.0.15 currently. Does your Module support this version of Ignition at all for the kind of messaging I need?
No. Ignition v8.1+ is required for this latest feature.
