Hi Guys,
I’m setting up the communication between two ignition gateways using default port 62541 to get the OPC tags from RSlinx OPC DA server through OPC tunnel function. I would like to simulate the communication interruption to check the data integration status. When I disabled the port 62541 at both server firewall and security group of AWS EC2, and confirmed the telnet can’t get the remote server response, however, the two gateways are still working well. Can anyone please explain this? or OPC UA used other protocol or ports after established communication here? thanks
