CompactLogix Device Disconnected
Hello there, im having an isue when trying to connect my AB CompactLogix L24ER-QB1B to ignition.
Ignition detect my device because when i change into run or program mode, ignition show the status of my plc… but it doesn’t conect. i dont know if i need a special configuration on mi plc or ignition…
the msj shown is this…
and status shows it…
if I click in devices and then details…
and the log show this msj…
i dont have any idea why this may occurring, i hope someone can help me
Since I see you have some aggregate statistics, it appears that you do have some communication.
What version firmware are you running on the PLC? It might be worth trying the newer Logix Driver instead of the legacy drivers.
omg, since i followed the ignition tutorials i never tried to change the type of plc when configuring it because it was a compactlogix… now that you said me that… it connected with the logix driver…
i imagined that it was caused because my firmware is higher that 21…
thanks you so much!! i lost 2 days with this problem :C …
