When setting up a vision client with a company internally signed SSL certificate it seems relatively easy to select the trust button when adding the application in the vision client launcher, but I didn't see an option to trust the certificate of the redundant server at the same time. Is there a folder I can load certificates to or a way to trust all certificates issued by the companies internal certificate authority?
You can add the root CA cert as trusted: Launcher Settings - Ignition User Manual 8.1 - Ignition Documentation
Hmm, and it looks like as of 8.1.19 you can direct the launchers to use the OS root certificate store instead... search "trust.store" on that same page in the user manual.
I'll try adding the root CA cert and test if that works.
